How to call system property in catalog client script
03-24-2023 12:59 AM
how to call a system property on a Catalog client script?
I have defined a system property where the Value is one catalog item (AB). And for this catalog in state field On Hold option is there.
Now Requirement if in future someone add other catalog item sys_id in system property so for that item also state field option on hold should be add.
Client script-
system properties-
if someone add other item sys_id in value so for that catelog item on hold option should come in (sc_task) state field.
Thanks.
03-24-2023 01:48 AM
use this
function onLoad() {
var ga = new GlideAjax('PropertyUtilization');
ga.addParam('sysparm_name', 'getProperty');
ga.getXML(myCallBack);
function myCallBack(response) {
var prop = response.responseXML.documentElement.getAttribute('answer');
if (g_form.getValue('sc_task.request_item.cat_item') == prop) {
g_form.addOption('state', '5', 'On Hold', '2');
