Issue with the Else block in ServiceNow flow
jay_15
I am facing strange issue where Else block is erroring out in flow designer without even going inside the else steps. Request for help
The If condition is evaluated false resulting in Else block, but then the flow simply fails with error.
Encountered error executing instruction: GetFlowOutputsInstruction{id=92, io=Io{input={__quick_api_execution=RefOrValue{value=c19o.__quick_api_execution, isRef=true}, __fail_on_error=RefOrValue{value=true, isRef=false}, __dont_treat_as_error__=RefOrValue{value=c19o.__dont_treat_as_error__, isRef=true}, __state=RefOrValue{value=c19o.__state, isRef=true}, context=RefOrValue{value=c19o.context, isRef=true}, __sub_flow_id=RefOrValue{value=c19o.__sub_flow_id, isRef=true}, wait_for_completion=RefOrValue{value=true, isRef=false}, __action_status__=RefOrValue{value=c19o.__action_status__, isRef=true}, __context_state=RefOrValue{value=c19o.__context_state, isRef=true}}, output={__quick_api_execution=c19o.__quick_api_execution, __dont_treat_as_error__=c19o.__dont_treat_as_error__, __state=c19o.__state, __sub_flow_id=c19o.__sub_flow_id, __action_status__=c19o.__action_status__, __context_state=c19o.__context_state}, defaultOutput={}}}, errorMessage:No Record Found, errorCode:1
Jaydeep
kcannam
Mega Contributor
@jay_15 ,
Hello, have you found any solution as I am facing same issue,
Brian15
I'm also looking for a solution to this issue.
