Problem with ServiceNow studio
RóbertF
What to do in this situation?
glideFather
Hi @RóbertF,
it seems that the URL path leads to nowhere.. how did you get there? was it redirection from some location or do you know?
You can go to the AES by navigating to this:
https://yourinstance.service-now.com/now/appenginestudio/home
✂-----Cutting-out-the---✦AI-noise✦---All-replies-written-and-vouched-for-by-GlideFather---
Tanushree Maiti
Hi @RóbertF
If it is used to working and recently stop working like post upgrade , then will suggest to go for Plugin Repair.
Tanushree Maiti
Tejas Adhalrao
hi @RóbertF  ,
Open  studio from
2) or use url
  …...com/now/servicenow-studio/home
3) clear cache using cache.do
4)check plugin is activated or not
