Process flow of configuring technology portfolio management
shrutivsriv
I wanted to understand the exact flow of how technology portfolio management works…. What are the basic plugins are needed and how does the technology portfolio fetches the scores and risks? How to configure so that we can populate the output in technology portfolio.
Any help will be appreciated.
Thanks in advance!
Anantha Gowrara
Hi @shrutivsriv , To implement TPM you must have TPM,SAM and APM plugin installed and main important factor is your software models. business applications and app Services. If you are using service mapping, this structure should already be present and hierarchy is maintained. in TPM there will be one dashboard which analyses your software models and identifies potential risk. The main important factor for TPM implementation is maintaining the hierarchy of business apps, apps services and your software products(which may have multiple models)
Hi Anantha, Thank you for your input. I tried the mapping of Application services to software model lifecycle but final scores are not getting generated. Is there a way to generate it like in APM?
