best practices in using ServiceNow for project management
PrabodhG
Mega Contributor
I need some material on "best practices in using ServiceNow for project management" urgently. Can anyone share please? Thanks in advance
Dr Atul - LNG
Hi @PrabodhG
To find the best practices, you need to go to the best place, which is Now Create. Go to Now Create, search for 'Project Management' under assets, and you'll find a few documents that might have best practices or guide you on how to use Project Management in ServiceNow."
https://learning.servicenow.com/nowcreate
