Need Help on Catalog client script
vinitaraico
Hi Team,
There is one  variable A-  type -select box in the catalog .This select box  have option 1,option2,otions3,option4. This Catalog variable is part of variable set and variable set is configure in multiple catalog ,Now I have added 2 more option in this variable A
Now my requirement is  the newly added options should be visible only in 2 catalog ,How I can achieve this using client script
@vinitaraico
Hope you are doing good.
@vinitaraico
Glad to know that my script worked.
@vinitaraico
