Validate Lifecycle combination Business Rule error in Flow Designer
Lucky1
Hello all,
When I am trying to update a Business Application record from flow designer,
I am updating with Status --- Retired, Life Cycle Stage ---- End of Life, Life Cycle stage status --- Retired.
the record is not getting updated with the values, instead it is giving error in the flow executions.
I have checked the business rule, and also checked the entries in Life cycle control table and Life cycle mappings table, but not understanding clearly how it works and why I got that error.
I see the Life cycle Mappings table record like this:
Life cycle Control table:
So, in the workflow I am doing the right thing only, then why it is throwing an errror?
Can someone help me how to update the record with these values without error.
Please I cannot use custom action and write gr.setWorkflow(false).
Thanks in advance.
Lucky
12 REPLIES 12
Ankur Bawiskar
@Lucky1
the error clearly tells some before update business rule stopped/aborted the update.
Did you check if that BR condition and script is actually blocking?
Hello Ankur,
It is oob BR and oob read-only script include.
Hence I copied the Script include code and created a new Script include to put logs.
and in the BR, i commented the original one, and triggered my Script include.
Lucky
Damhoej
I have the same issue in my PDI, and before I try myself: Have you complete the journey to use Life Cycle?
I am on Zurich patch 3 and in that I stilla have to go through the Life Cycle Sync (and install CSDM Activation after)
