Why Event Management Fundamentals's participant guide
alanshen
Why Event Management Fundamentals On Demand and Discovery Fundamentals On Demand
don't have the  participant guide library book?
2 ACCEPTED SOLUTIONS
AJ_TechTrek
Hi @alanshen ,
You can check with ServiceNow directly on this, Refer the below contact details related article.
https://learning.servicenow.com/lxp/en/get-started-with-servicenow-university-resources?id=kb_articl...
Please appreciate the efforts of community contributors by marking appropriate response as Mark my Answer Helpful or Accept Solution this may help other community users to follow correct solution in future.
Thank You
AJ - TechTrek with AJ - ITOM Trainer
LinkedIn:- https://www.linkedin.com/in/ajay-kumar-66a91385/
YouTube:- https://www.youtube.com/@learnitomwithaj
Topmate:- https://topmate.io/aj_techtrekwithaj (Connect for 1-1 Session)
ServiceNow Community MVP 2025
@alanshen
Glad your question was answered.
As per community guidelines, you can mark more than one answer as Accepted Solution. If my response helped to answer your query, please mark it helpful & accept the solution.
Bhuvan
9 REPLIES 9
Dr Atul - LNG
Hi @alanshen
As per some information (which may or may not be correct), since users were downloading and using these eBooks illegally, ServiceNow has restricted almost all eBooks except for the CSA. This might be true, but it’s better to log a Now Learning case, and the team can provide you with a proper justification.
Hi @alanshen
This is what i replied, please check.
alanshen
I raised a case, the answer is Event Management Fundamentals On Demand and Discovery Fundamentals On Demand do not have ebooks.
Thanks all the replies above.
@alanshen
Glad you got the clarification from Now Learning support.
If the post helped to guide you on finding a solution, please mark it helpful & accept the solution.
Bhuvan
@alanshen
Bhuvan
