Email Script to include Variables, Variable Sets, and their values
MyriahM
Our current script [shown below], created by our implementation partners, is pulling the sys_id instead of the display name for the reference fields within the variables [Approver, Requested for] in our email script. We are reaching out to see if someone might have a fix for this. Also, on a side note, we are looking to include variable sets as well. Any help and/or guidance would be much appreciated.
Script:
(function runMailScript(current, template, email, email_action, event) {
    var html = '<h2>Summary of Requested Item</h2>';
    var reqItem = new GlideRecord("sc_req_item");
    reqItem.addQuery("sys_id", current.sysapproval);
    reqItem.query();
    if (reqItem.next()) {
        html += '<h3>Request Details:</h3>';
        html += '<table border="1" cellpadding="5" style="border-collapse: collapse;">';
        html += '<tr><td><strong>Request Item:</strong></td><td>' + reqItem.number + '</td></tr>';
        html += '<tr><td><strong>Requested for:</strong></td><td>' + reqItem.requested_for.getDisplayValue() + '</td></tr>';
        html += '<tr><td><strong>Item:</strong></td><td>' + reqItem.cat_item.getDisplayValue() + '</td></tr>';
        html += '<tr><td><strong>Quantity:</strong></td><td>' + reqItem.quantity + '</td></tr>';
        html += '</table>';
        html += '<h3>Variables:</h3>';
        html += '<table border="1" cellpadding="1" style="border-collapse: collapse;">';
        var variables = new GlideRecord("sc_item_option_mtom");
        variables.addQuery("request_item", reqItem.sys_id);
        variables.orderBy("sc_item_option.item_option_new.order");
        variables.query();
        while (variables.next()) {
            var itemOption = variables.sc_item_option.item_option_new;
            var label = itemOption.getDisplayValue();
            var value = variables.sc_item_option.value;
            // Handle reference fields - FIX APPLIED HERE
            if (itemOption.type == 'reference' && value) {
                var refTable = itemOption.reference;
                if (refTable) {
                    var refGR = new GlideRecord(refTable);
                    if (refGR.get(value)) {
                        value = refGR.getDisplayValue(); // Always get the display value
            // Handle checkbox display
            if (itemOption.type == 'checkbox') {
                value = (value == 'true') ? 'Yes' : 'No';
            if (value && value.trim() !== '') {
                html += '<tr><td><strong>' + label + ':</strong></td><td>' + value + '</td></tr>';
        html += '</table>';
    template.print(html);
})(current, template, email, email_action, event);
Hi @MyriahM ,
    reqItem.query();
        html += '</table>';
        variables.query();
            if ((itemOption.type == 'reference' || itemOption.type == '8') && value) {
                if (refTable) {
        html += '</table>';
    reqItem.query();
        html += '</table>';
        variables.query();
            var itemOptionType = itemOption.type;
            if ((itemOptionType == '31' || itemOptionType == '8') && value) {
                if (refTable) {
        html += '</table>';
try this
Chaitanya
Hi @MyriahM
Sure
I have updated the if condition with backend values of variable types
In the backend for reference it 8 and for requested for its 31
If you go to any variables and check the choices of Type field the backend values are different
You can  go to the sys_choce table to find the background values or if you have SNUtis with show technical names feature it shows the backend values of chices
Chaitanya
