Fix Script
Shreshta_happy
They are some inflight tasks that I need to reassign to the other group.
i have written this fix script:
var techUpgrade= new GlideRecord('case table');
techUpgrade.addEncodedQuery('u_tech_upgrade_type=');
techUpgrade.query();
while (techUpgrade.next()) {
    gs.log("it is for non tu" + techUpgrade.number);
    var GroupUpdate = new GlideRecord('task table');
    GroupUpdate .addQuery('u_parent', techUpgrade.sys_id);
GroupUpdate .addQuery('u_type', 'task');
    GroupUpdate .addQuery('u_assigned_group', 'IN', 'f53cecacdbf8f5109aa69reerrwer');
    GroupUpdate .query();
    if (GroupUpdate .next()) {
        gs.log("checking for the second remtask + techUpgrade.number);
        GroupUpdate .seValue('u_assigned_group ', '6ebd91f387593510f484b806dabdfdf443');
        GroupUpdate .setWorkflow(false);
        GroupUpdate .update();
The logs are getting executed but the group is not getting updated
Please help.
14 REPLIES 14
@psphanindrakuma Good catch mate. @Shreshta_happy Please use correct sys_id here.
@Shreshta_happy
And also you can use
techUpgrade.addNullQuery('u_tech_upgrade_type');
I have given a dummy sys_id here.
newhand
HI@Shreshta_happy
Did you  uncheck  the "Record for rollback" check box ?
Please mark my answer as correct and helpful based on Impact.
Ankur Bawiskar
@Shreshta_happy
there is a space after your field name and I removed it
please use this line
GroupUpdate .seValue('u_assigned_group', '6ebd91f387593510f484b806dabdfdf443');
Certified Technical Architect  ||  9x ServiceNow MVP  ||  ServiceNow Community Leader
