g_model workspace popup doing same function if i click on cancel or close the popup using cross???
KM SN
Actually for my requirement i have to show popup having "create new' and 'add from existing' button but as i am unable to find it ...i have used  g_model.confirm() and i have written create new functionality on click on ok and add from existing functionality on click of cancel.
but even if i close popup using cross cancel functionality is working . how to avoid it? or else is there any other possibility except g_model  to show popup in workspace.
let me have your ideas here.
@Prince Arora  @Ankur Bawiskar  @Rahul Kumar17  @K Akhila @AndersBGS @Anurag Tripathi @AnveshKumar M @Bharath Kumar A @Sandeep Rajput
Same thing will happen if you click on close button.
try this -
function onSubmit() {
    var isnew = g_form.isNewRecord();
    if (isnew) {
if(!g_form.getValue('constituent_pofile')){
        if (g_scratchpad.isFormValid)
            return true;
        var first_name = g_form.getValue('x_guid2_child_welf_first_name');
        var last_name = g_form.getValue('x_guid2_child_welf_last_name');
        var dob = g_form.getValue('date_of_birth');
        //var result = '';
        var script_include = new GlideAjax('ChildInformationUtils');
        script_include.addParam('sysparm_name', 'getrecord');
        script_include.addParam('sysparm_first_name', first_name);
        script_include.addParam('sysparm_last_name', last_name);
        script_include.addParam('sysparm_dob', dob);
        script_include.getXMLAnswer(setAnswer);
        return false;
function setAnswer(answer) {
//alert(answer);
		var checkExist = setInterval(function() {
		if (top.document.getElementsByClassName('close pull-right')[0]) {
			clearInterval(checkExist);
			var x = top.document.getElementsByClassName('close pull-right')[0];
			x.style.display = "none";
	}, 100); // check every 100ms
            if (answer != null) {
                var url = '' + top.location.href;
                if ((url.indexOf('agent') > -1)) {
                    var msg = "User is already exists in the system, Please select required action form below";
                    g_modal.confirm(getMessage("Confirm"), msg, function(confirmed)
                            if (confirmed == true) {
                           g_form.setValue('constituent_pofile', answer);
                                 var actionName1 = g_form.getActionName();
                                    g_scratchpad.isFormValid = true;
                                     g_form.submit(actionName1);
                                return false;
else if(confirmed == false) {
var actionName2 = g_form.getActionName();
                            g_form.submit(actionName2);
return false;
// alert('its native ui right?');
// alert(answer);
                    var gm = new GlideModal('x_guid2_child_welf_child_window_dialog_box', true, 600);
                    gm.setTitle('Confirm');
                    gm.setPreference("sysparm_fname", first_name);
                    gm.setPreference("sysparm_lname", last_name);
                    gm.setPreference("sysparm_dob", dob);
                    gm.setPreference('sysparm_search', answer);
                    gm.render();
                var actionName = g_form.getActionName();
                g_form.submit(actionName);
KM SN
thats where i am ..if i click on cancel i have written some functionality its going to work but when i click on cross simply it has to close window nd nothing should happen.
anyhow this is also not working bro.
BTW cross and cancel works as same behavior.
In your scenarios what is happening when click on cancel and cross.
KM SN
as you said...cross and cancel working as same.
but I want to make cross should close just the window where as cancel button has to work as I written functionality for it.
do you have anything suggestion to show pop up like with our own options instead of this g_model.
