I want to fire an event in Flow Designer
hurm
Hi All
I want to raise an event in the flow and send an email
I'm not familiar with triggering events.
I want to start an event in the 【sysevent table】 with 【create record】 action, but I can't see the event table.
Please let me know if there is another way
Please help me
14 REPLIES 14
The team has disabled the event table from being searched, so I would prefer not to change it, thank you.
@hurm
then you cannot do anything here.
the only way is to use Custom action and use script to insert record into that table using GlideRecord
newhand
@hurm
I'm not sure if i have got your question。
Do you want to send an email from notification  and the nofification trigger is  event ?
If yes,  you need to regiest an event ( All ->System Policy -> Events -> Registry  )
and set it to the notification trigger (on the "when to send " tab).
then, you can trigger the notification to send an email by fire the event you created via "gs.eventQueue"  script command.
Please mark my answer as correct and helpful based on Impact.
hurm
YES, send email on event
I will post the results of my research here
[eventQueue(String name, Object gr, String option1, String option2, String event_queue)]
What action fills [gs.eventQueue] and raises an event?
I have never written a script with flow
@hurm
I didn't find an existed flow action that can be used directly。
But you can create an action with script step and fire the eventQueue in the script step.
