Module navigation in ATF
In ATF i want to add a step like open specifications.list while using application navigator there r product specification, service specification modules but how to open whole specifications.list using ATF.
Ankur Bawiskar
you can open table list using ATF only when you have module for it
Once you open that module you can apply filter to the list and then open the record
Ankur Bawiskar
Thanks, so if we don't have a specific module then we can't navigate to it right?
correct.
Just follow the instruction @Ankur Bawiskar gave you but you will open the view page that contains the table list with ATF and make sure the module is attached  to it and syncronize or filter the record list will display.
