Add Child of Incidents to Problem tickets
Cat
Hi all,
We may attach a parent incident to a problem. Is there a way to add the list of child incidents to the problem? These are incidents where they are only attached to the parent - not the problem. Only the parent would be attached to the problem.
Cat
12 REPLIES 12
Thank you! I followed this, but it unfortunately didn't show any tickets in the new tab despite there being some attached to the parent.
I put it through CoPilot to see if it could help - it showed items but it listed every single incident if there was nothing in  "first reported by" or if the first reported was a request. I'm not to great with javascript yet - do you have any ideas? The copilot script is below
(function refineQuery(current, parent) {
    // Find all incidents associated to the Problem
    inc.addQuery('problem_id', parent.sys_id);
    inc.query();
    var parentIncidents = [];
    while (inc.next()) {
        parentIncidents.push(inc.getUniqueValue());
    // If no parent incidents, stop here
    if (parentIncidents.length === 0)
    // Now find child incidents of ANY associated incident
    var children = [];
    var gr = new GlideRecord("incident");
    gr.addQuery("parent", "IN", parentIncidents)
        .addOrCondition("parent_incident", "IN", parentIncidents);
    while (gr.next()) {
        children.push(gr.getUniqueValue());
    if (children.length > 0) {
        current.addQuery('sys_id', 'IN', children);
})(current, parent);
@Cat
I did share screenshots confirming approach worked fine for me
Dr Atul - LNG
Got it, mate. But I would still recommend trying to stick with the out-of-the-box (OOTB) approach.
