After BR is not running
12-18-2024 11:15 PM
Hi Everyone,
I have created a simple After insert,update BR on SG-Intune Computer Related table,where it shows a Infomessage message.But that BR is not running.
Can anyone help me on this
Thanks in Advanced
12-19-2024 06:34 AM
12-19-2024 12:34 PM
un-check Advanced if you're not using script logic.
12-19-2024 06:34 AM
How are you validating this BR? Are you creating a record manually in that table or are you using any transform map to populate this table?
If you are using transform map, make sure Run Business Rule is checked. Otherwise, your BR will not get executed
12-19-2024 06:35 AM
12-22-2024 06:47 PM
did you try enable debug business rule and see if any other BR is aborting and stopping this?
