‎08-19-2015 04:22 AM
Hi there,
I'm figuring out the best way to do this..
In my form, I have 2 fields: caller and hospital.
Caller refers to the users table, Hospital refers to the company table.
My goal is: whenever I populate the caller field, the system needs to lookup the hospital of that caller and needs to auto-populate that.
Example: Customer X is part of Hospital X. Customer X is the caller so will be populated in the caller field. The system recognizes that Customer X is part of Hospital X so hospital will be Hospital X.
Hope you guys can help me out!
‎08-21-2015 06:53 AM
We got it working!
Client script:
var ga = new GlideAjax('GetCustomerData');
ga.addParam('sysparm_name','getFieldValue');
ga.addParam('sysparm_field','u_reference_1');
ga.addParam('sysparm_user_id', g_form.getValue('caller'));
ga.getXML(DoSomething);
function DoSomething(response) {
var company = response.responseXML.documentElement.getAttribute("answer");
g_form.setValue('company',company);
Script include:
var GetCustomerData = Class.create();
GetCustomerData.prototype = Object.extendsObject(global.AbstractAjaxProcessor, {
getFieldValue: function() {
var user = new GlideRecord('x_medt2_ihs_customers');
user.get(this.getParameter('sysparm_user_id'));
if(! user.sys_id){
return false;
return user[this.getParameter('sysparm_field')];
Thanks everybody for the great help on this!
‎08-20-2015 05:37 PM
You need to add 'global' to AbstractAjaxProcesser in scoped applications.
‎08-20-2015 02:02 AM
Then, try this:
var caller = g_form.getReference('caller_id', getHospital);
function getHospital(caller) {
alert(caller.name);
alert(caller.u_reference_1);
g_form.setValue('company',caller.u_reference_1);
on getReference you have to specify the name of the column.
‎08-20-2015 07:47 AM
You could also do it like this:
var hospital = g_form.getReference('caller').u_reference_1;
g_form.setValue('company', hospital);
‎08-20-2015 08:47 AM
Mike, the problem with that is that Caller points to [sys_user] table, and u_reference_1 is a field of a child table, so g_form.getReference('caller').u_reference_1; would return 'undefined'.
‎08-19-2015 07:22 AM
Hi Rick,
You can achieve the above req with the help of dot-walking. Please go through the below link for more info.
http://wiki.servicenow.com/index.php?title=Dot-Walking#gsc.tab=0
