Building a UI Page, Issue using GlideAjax in Client script
Kapil Chopra
I am trying to get value in UI Page Client Script via GlideAjax,however when I try to destroy the window it doesn't close the UI page or save the record.
This UI Page is called via UI action has only one reference field
var gaLoc = new GlideAjax('someutil');
gaLoc.addParam('sysparm_name', 'getLocation');
gaLoc.addParam('sysparm_assignmentGrp', 'Location');
gaLoc.getXML(assgnLocSysid);
// the callback function for returning the result from the server-side code
function assgnLocSysid(response) {
g_form.setValue('assignment_group', assigmentgrp);
g_form.setValue('location', answer);
GlideDialogWindow.get().destroy();
g_form.save();
Sohail Khilji
try :
  g_form.save();
try to log and see if you get the data. if not fix the serverside script to fix it...
if you are using OOTB location field then it is a reference field so while setting this field make sure you are setting record's sys_id to the location.
