Call a function inside a script include using a variable
hermanwinkel
Giga Contributor
i have a script include that has 3 functions. lets call them function a, b and c
from function a i want to call function b OR c depending on a variable given by the businessrule thats calling function a.
the variable has the function b or c as value.
is it possible to call the function like this inside function a, with a variable? I know I can code around it with a IF, but i have 20 more functions that can be called. so i would get 20 IF statements.
a : function(functioName) {
do something...
var callFunction = functionName+'()';   // callFunction = 'b()'   or 'c()'
var value = this.callFunction; // this will go to the function b or c
b : function {
do something
c : function {
do something else
thank you in advance
hermanwinkel
Giga Contributor
I found a solution.
i have to use the javascript funtion eval() https://developer.mozilla.org/en-US/docs/Web/JavaScript/Reference/Global_Objects/eval
this way i can execute a string as javascript!
Hm... eval() is generally considered not a good option. Have you tried
var callFunction = 'b'; // or 'c'
this[callFunction]();
In JavaScript, this.method() is the same as this['method']() Then you can specify the function name as a string.
