cancel workflow from flow or using Business rule
sarasaamani
i'm not sure how to create run script activity in flow , need some guidance on this
alternatively, I tried with after Business rule with script as below, it's just setting flow context to cancel and i still can view the workflow from show workflow option. How do i remove the workflow completely?
 if ((current.stage == 'Request Cancelled') && current.context
          && !current.context.nil()) {
      var w = new Workflow();
      var now_GR = new GlideRecord('wf_context');
      if (now_GR.get(current.context))
          w.cancelContext(now_GR);
@sarasaamani
that Related link is not visible to all
what's the point in this requirement if the workflow is already cancelled via your script
@sarasaamani
Hi @Ankur Bawiskar
that show workflow link is still visible to end users. my br just setting workflow context to cancelled. is there a way to remove that workflow completely?
@sarasaamani
you can update the UI action condition but it's an OOB UI action
Also why end users are seeing that button?
HI @sarasaamani
Can we do like this, I have used a Before Insert BR on my custom table and running this script....
var rec = new GlideRecord('u_customTable');
rec.addQuery('number', current.number);
rec.query();
if (rec.next()) {
var workflow = new global.Workflow();
workflow.cancel(rec);
gs.info("Existing Recors is " + rec.sys_id);
