‎12-18-2023 09:27 PM
Hi i have this script include that when the drop down is modify or remove all it shows the groups user is part of in a servicenow group field (i.e a list collector) but for some reason the value is not setting in the field anymore and it isn't showing all the groups the requested for is part of this was working perfectly till yesterday but suddenly it stopped working can someone please help me out with this
this is my script include
var getAssignmentGroupofMember = Class.create();
getAssignmentGroupofMember.prototype = Object.extendsObject(AbstractAjaxProcessor, {
getAssignmentGroup: function() {
var getUser = this.getParameter("sysparm_requestedForValue");
var getType = this.getParameter("sysparm_type_is");
gs.log('11-12-23 type is ' + getType);
gs.log("11-12-23 sys_id: " + getUser);
if (getType == 'remove_all') {
var grm = new GlideRecord('sys_user_grmember');
grm.addQuery('user', getUser);
grm.query();
var grpArray = [];
while (grm.next()) {
grpArray.push(grm.getDisplayValue("group"));
gs.log("member group array 812" + grpArray+'user is'+getUser);
return grpArray.toString();
// gs.print(grpArray);
// gs.print(grpArray[0]);
} else if (getType == 'modify') {
var grp1Array = [];
var grm1 = new GlideRecord('sys_user_grmember');
grm1.addQuery('user', getUser);
grm1.query();
while (grm1.next()) {
grp1Array.push(grm1.getDisplayValue("group"));
gs.log('groups not in ' + grp1Array+'user is'+getUser);
//var a = grp1Array.toString();
return grp1Array.toString();
} //else if(getType == 'add') {
// var grm2 = new GlideRecord('sys_user_grmember');
// grm2.addQuery('user', getUser);
// grm2.query();
// var grp2Array =[];
// while (grp2.next()) {
// grp2Array.push(grm2.getDisplayValue("group"));
// gs.log('groups in' + grp2Array);
// return grp2Array.toString();
type: 'getAssignmentGroupofMember'
});and this is my client script
var g_form_item = g_form;
var requestedforValue = g_form_item.getValue('requested_for');
var type_is = g_form.getValue('request_type');
if ((type_is == 'modify') || (type_is == 'remove_all')) {
alert('User will be removed from the groups selected in ServiceNow groups after the group manager approval');
var ga = new GlideAjax('getAssignmentGroupofMember');
ga.addParam('sysparm_name', 'getAssignmentGroup');
ga.addParam('sysparm_requestedForValue', requestedforValue);
ga.addParam('sysparm_type_is', type_is);
ga.getXML(setAssignmentGroup);
function setAssignmentGroup(response) {
if (answer) {
//var pa=JSON.parse(answer);
alert(answer);
//g_form.clearValue('servicenow_groups');
g_form.setValue('servicenow_groups',answer);
}can someone please help out as it is urgent.
‎12-18-2023 09:36 PM
according to your Script Include you are returning display values from table sys_user_grmember:
But this is wrong, as list collector fields store Sys IDs.
Instead, use something like this:
grp1Array.push(grm1.getValue('group'));
Use this approach everywhere in your script and adopt the script code accordingly.
Maik
‎12-19-2023 03:04 AM
Can you try below logic in your client script to set the field value :
var answer= response.responseXML.documentElement.getAttribute("answer");
if(answer){
var final_value = answer.split(",");
var length = final_value.length;
for (var i = 0; i < length; i++)
g_form.addOption('servicenow_groups', final_value[i]);
Thanks & Regards
Amit Verma
‎12-19-2023 04:12 AM
Can you please accept the solution if it solved your issue ?
Thanks & Regards
Amit Verma
‎12-19-2023 08:46 AM
Hi Ramsha,
Why to run the client script instead, why not the variable be a reference field and with a filter query condition?
