Client script for reference qualifier
charanpatnala
Hello Team, I am trying to write a code for variable in a variable set of type reference which should filter the table it is referencing and populate with two possible values using onLoad catalog client script. I tried but haven't found a solution for that can you help me to solve this thanks in advance.
9 REPLIES 9
@Ankur Bawiskar as I mentioned it is in a variable set if I change it will affect all the catalog's in which it was included so, I need to write a script for this
@charanpatnala
then you can write onChange catalog client script which Applies to your Catalog Item and your variable
Then check if user has selected either of those 2 options
If not then show an field message with error for that variable
something like this
    g_form.hideFieldMsg('variableName');
    if (newValue == 'sysId1' || newValue == 'sysId2') {
        // do nothing
        var message = 'Please select either of these 2 values';
        g_form.clearValue('variableName');
        g_form.showFieldMsg('variableName', message, 'error', true);
@charanpatnala
thank great
phgdet
Hi @charanpatnala,
The function getDynamicValueFieldRefQual returns a query. In your own function, you can use that variable set to return a default query for other record producers while filtering the referencing table for your specific record producer.
