Client Script onChange does not work first time around
Lee Jones
I'm relatively new to ServiceNow Client Scripts. I'm trying to write a script that makes the 'comments' field mandatory specifically when incident 'state' changes to newValue In Progress (2), from oldValue New (1).
The script seems to work successfully, apart from when I initially change the state field. All subsequent state changes work as expected, just not the first.
Example: I open an incident which is in state New. I select 'In Progress' from the dropdown - State is not mandatory. I then select another state from the drop-down before reselecting 'In Progress' - only then does State become mandatory.
I have tested this in both a PDI (Utah) and my organisations dev environment (Utah). Both have the same outcome. I would appreciate some help with this. Many thanks.
Script:
function onChange(control, oldValue, newValue, isLoading, isTemplate) {
   if (isLoading || newValue === '') {
   //Type appropriate comment here, and begin script below
   if(newValue == '2' && oldValue == '1'){
        g_form.setMandatory('comments',true);
        g_form.setReadOnly('work_notes',true);
        g_form.showFieldMsg('comments','Please enter a customer update, preferably using a suitable template','info');
    else {
        g_form.setMandatory('comments',false);
        g_form.setReadOnly('work_notes',false);
        g_form.hideFieldMsg('comments','Please enter a customer update, preferably using a suitable template','error');
That is weird.
I wonder if there is another script running at a latter order or a ui policy that overrides the comments field behavior
