Converting business rule to fix script
Enkhdalai
I want to convert business rule to fix script.
Below is the business rule:
var ip = current.ip_address;
var ips;
if (current.ip_address.startsWith("192.168.0.")) {
current.u_network_zone = "DC - CDE";
ips = ip.substring(10);
if (ips < 128) {
current.u_dc = "Seoul";
current.u_dc = "Jukov";
current.u_is_connect_to_internet = 0;
current.u_is_use_card_information = 1;
current.u_is_deliver_user_information = 1;
current.u_va_total_score = 2;
})(current, previous);
What this business rule do is filters CI's ip address and sets some fields value to certain value.
Abhijit4
You can use below script,
var ips,ip;
var grCMDB=new GlideRecord("cmdb_ci_server");
grCMDB.addEncodedQuery("ip_addressSTARTSWITH192.168.0.");
grCMDB.query();
while(grCMDB.next()){
ip = grCMDB.ip_address;
if (ips < 128) {
grCMDB.u_dc = "Seoul";
grCMDB.u_dc = "Jukov";
grCMDB.u_network_zone = "DC - CDE";
grCMDB.u_is_connect_to_internet = 0;
grCMDB.u_is_use_card_information = 1;
grCMDB.u_is_deliver_user_information = 1;
grCMDB.u_va_total_score = 2;
grCMDB.update();
Let me know if you have any further queries.
Please mark this as Correct or Helpful if it helps.
Thanks and Regards,
Abhijit
By marking my response as correct or helpful, you contribute to helping future readers with similar issues.
Abhijit
ServiceNow MVP
Hi Enkhdalai,
You apply the same filter on CI table as follows
then right click on the query and copy it as follows
Then paste it within the encoded query.
It will be 'ip_addressSTARTSWITH192.168.0.'
Abhijit4
var ips,ip;
grCMDB.query();
if (ips < 128) {
grCMDB.update();
Thanks and Regards,
Abhijit
Abhijit
ServiceNow MVP
Hi Abhijit, this one worked. Thanks a lot.
