04-11-2018 07:21 AM
I have a catalog item that has a core_company reference variable. When a test user with no roles tries to populate it, the field returns "no matches found".
I've added an ACL for core_company.* with no roles, no conditions, and no script but the field continues to return "no matches found". When the test user tries to access /core_company_list.do, it gets the the following security debug:
Security constraints prevent access to requested page
04-11-2018 07:53 AM
Hi Snow3,
You also need to give table level access
create table level ACL i.e. Core Company and none ACL and it should work.
Mark Correct if this solves your issue and also hit Like and Helpful if you find my response worthy based on the impact.
05-14-2018 01:39 AM
Hi Snow3,
Any update on this?
Can you mark answer as correct, helpful and hit like if you were able to achieve the requirement. This helps in removing this question from unanswered list and helps users to learn from your thread. Thanks in advance.
