Creating an INC and INC Task using flow designer
sailor_moon
I'm creating a flow designer wherein the trigger is inbound email that will generate an INC record once it received the email. My question is how can I get the incident number to populate the incident number in incident task table as well as the category and subcategory.
This is what I always got after running the testing
I tried to use a code
var incNumber = fd_data.trigger.inbound_email.incident;
return incNumber;
But it's also didn't work, please help me to resolve this. Thank you!
RAMANA MURTHY G
Hello @sailor_moon ,
Please look at below screen shot
You can select Incident number using data pill feature,
Plese mark my answer as helpful, if it helps you
Thank you
Please mark my answer helpful & correct if it helps you
Thank you
G Ramana Murthy
ServiceNow Developer
Sujit Jadhav
Hello @sailor_moon
Try
var num = fd_data.create_task.number
Return num;
In script action, try above script
Please mark this as correct answer and helpful if it resolved, or mark this helpful if this help you to reach towards solution.
Ayushi12
Hi @sailor_moon,
Use data pills to store the incident number and update it in the incident task.
Refer:https://developer.servicenow.com/dev.do#!/learn/learning-plans/utah/new_to_servicenow/app_store_lear...
vermaamit16
Hi @sailor_moon
Is you flow responsible to create the incident or the incident is being created from Inbound email action ?
Thanks & Regards
Amit Verma
Thanks and Regards
Amit Verma
RAMANA MURTHY G
Thank you
Thank you
G Ramana Murthy
