Difference between Locked Out users and Inactive Users
devd1
I am very new for SNOW Tool. Could you please help me to get the difference between Locked Out users and Inactive Users. Thanks in Adv...
Chuck Tomasi
Hi Devendra,
Locked out means they cannot login but are in the system as a current user (e.g. existing employee who tried the wrong password too many times.)
Inactive means they are no longer with the organization (e.g. active=true is a handy way to filter out ex-employees.)
12 REPLIES 12
njogb
Really helpfull thank you so much Chinmay Batra
ankit_gupt
Giga Contributor
  • Locked Out:
    • A user account is marked as "locked out" when too many failed login attempts occur (based on system security settings).
    • The user cannot log in until the account is manually unlocked by an administrator or after a specific time (if auto-unlock is configured).
  • Active:
    • An "active" user account means the account is enabled and can be used to log in and access ServiceNow.
    • If the Active checkbox in the user's profile is unchecked, the account becomes inactive, preventing the user from logging in, even if credentials are correct.
ankit_gupt
Giga Contributor
  • Locked Out: A user account is marked as "locked out" when too many failed login attempts occur (based on system security settings).
  • Active: An "active" user account means the account is enabled and can be used to log in and access ServiceNow.
