‎02-11-2022 01:49 PM
Hello developers,
I know this question has been asked several times and I researched each different way but I haven't had any luck.
The backstory is that I'm building out a catalog item and once its submitted it goes through a workflow using flow designer. However, once I get the catalog variables, I want to send an email to certain individuals once the request is created, which I have that part working. The problem is that I'm trying to get all of the catalog variables in that email. I know I can just drag and drop the data pills but instead of giving me the display values, I'm getting the sys ids. So I tried using a script to pull in the catalog variables, which technically works but it only gives me the first variable and not all of them. Is there a way to get the display value of all the catalog items dropped into the email using flow designer?
Here's a copy of my script:
Here's the context of what I'm using it for:
Scripting and Coding
‎02-11-2022 02:43 PM
The problem with your script is that you use "return" to early, it stops the script and returns, so the rest of the script is not evaluated.
You can change your script into something like this:
var mailtext = '';
var submitter = fd_data.trigger.request_item.variables.submitter.getDisplayValue();
mailtext += 'Requested by: ' + submitter;
var emailt = fd_data.trigger.request_item.variables.email_address.getDisplayValue();
mailtext += 'Email address: ' + emailt;
//... and continue on with all the other variables
return mailtext;
‎02-16-2022 10:31 AM
I also agree with Nia, you should use the low code approach whenever possible.
Although in some cases it is still necessary to write some code.
Regarding your issue with expanding a List collector variable, you could do a workaround, to get the records needed.
A List collector is actually only a comma separated string of sysIDs to records on a specific table.
So if you would need you could first retrieve the records by using the "Look up records" action, and in the condition field, select Sys ID in "List collector value"
Example below:
var mailtext = '';
return mailtext;
‎02-13-2023 07:11 PM
Hello everyone,
In Flow Designer, how can I script the "TO" field so if specific applications are checked then the email should only go out to the approvers for that applications. For example, I have about 20 applications listed on the form to be selected, but if only Longview and PRO apps are selected on the form , then email should only go out to the approvers in a single email string. Is that possible?
‎02-13-2023 11:10 PM
Hi Brian,
I would ask that as a new question.
But in general, the scripting should return a string that contains one or more email addresses that is used as senders in your email.
‎02-14-2023 08:44 AM
Will do, thank you.
