Flow Designer - Generic Flow & Create a Task using a custom table
Vish4
Looking to create a generic flow designer. Basically, created a custom table with rules on when tasks should be created with the below view:
Type of Request (Input)Type of Application (Input)Short DescriptionAssignment GroupSequence
AddAAdd AGroup A1
AddBAdd BGroup A1
AddAAdd A - Create profileGroup B2
In this scenario, if a case is created for Add - A then there should be two tasks and if B is selected, 1 task should be created.
The flow I created has these steps:
- Trigger (when a case is created)
- Look up records (Gliding into the task flow table to retrieve the list of tasks for that scenario)
- Foreach loop and Create a task
Is there a better way to do it?
Maik Skoddow
In ServiceNow we have decision tables for such rules and output actions based on the rules. Please have a look on the following page where I have collected everything around that topic: https://www.servicenow.com/community/now-platform-articles/platform-decision-management-knowledge-am...
Vish4
Hi Maik, Any leads on how to do a foreach loop and create a task?
@Vish4 - Maik makes a great suggestion of using a decision table.
You could loop through the decision table, for each match create a task.
