Flow Designer - How can I access Soap request body using script from a SOAP step?
amala2
Giga Guru
I have a soap step configured in the Flow designer. How can I access the request body once the flow is executed?
Hitoshi Ozawa
Hi Amala,
Not sure about the question.
Following Now Support has information on using SOAP step. Response Body should be available in the Data pill of the SOAP step. If request body is necessary, should define and set it to the Output variable.
https://support.servicenow.com/kb?id=kb_article_view&sysparm_article=KB0852539
Sonali Lalit
Were you able to find the solution to this?
I passed the request body using an input variable and then accessed it after flow execution.
