‎08-30-2018 05:38 AM
I'm looking to use flow designer to remove users whose state changes from true from assignment groups and remove their system roles... has anyone done this before/know what table you would use for the action?
- 12,463 Views
‎08-30-2018 06:34 AM
Hi Alex,
You could definitely do this with flow designer. I mocked something up for what you could do for deleting group memberships and hasrole records:
‎04-15-2021 04:11 AM
Is there any limitation on Delete Record action on how many records it can delete in one execution. I'm using "Lookup Records" action and it returns thousands of records, it has OOB max result specified as 1K but flow execution throws error "Internal Server Error" while testing flow.
However, if i reduce look up records max results to 500 or less than that, it works fine. Any idea why its behaving this way.
‎04-20-2022 10:50 AM
For the look up for User Role Records stage I recommend adding the inherited is false condition.
The reason being is the deletion of the inherited roles will cause the flow to error out at the last stage of the flow.
The error for the last step of the flow is caused by the flow attempting to delete inherited roles in which the records cannot be deleted.
Below is what the Look Up users Roles Records condition should look like
‎02-18-2025 02:58 PM
To find Look up Records, you have to type the whole thing out or it will not appear unless it is a recent selection.
‎03-23-2020 07:58 AM
I'm trying to achieve something similar, but my trigger is a schedule that runs daily checking if there are some inactive users that need to be removed from groups.
However this flow results in an error, when I run it as 'system'.
It only seems to work as long as I trigger it as admin manually .
Any idea how to solve this?
‎07-06-2020 04:27 AM
HI,
I also have same issue, when I run it as System flow will not update record.But if I run it as admin it will work. Did you get solution for this?
Biji
