flow - Task issue
akin9
Hello Experts,
 "customer order"  is created with under 3 "product order"  from third party system .
once received our created flow will trigger with two subflows for order tasks creation for each product orders meaning every time 3 order tasks will create once that closed then another 3 tasks will be created. and its working fine.
Requirement/Question.
1.Two subflows are interconnected so added Do parellel condition its working fine.
I want to know  we need to add any wait condition for both subflows complete??
2. After subflows completed we want to create single "order task" but its creating
again 3 order tasks
how to achieve this?
Flow created for -- Product order table "sn_ind_tmt_orm_product_order".
Please support on this!
akin9
Hi @Runjay Patel
As per Lookup records counts are getting correctly 3 only.
Just verify these three record have value UNI and EVC.
Also did you check whether both sub flow executing or not? if not then check if statement.
Hi @Runjay Patel
Yes I checked record has the correct value.
and both subflows are not executing at same time .
From each condition i think bringing only one record to check the if condition.
Could you help me to check all the records instead of single record.
Okay, Do one thing.
Create 2 lookup record for both separately instead of running parallel.
