Glide aggregate max
sowmyaj
Giga Expert
        I'm not able to get the maximum count.
                            Based on my requirement I have result as 'A(value) - 3(count)' , 'B(value) - 3(count)', 'C(value) - 6(count)', 'D(value) - 10(count)', 'E(value) - 2(count)', 'F(value) - 1(count)','G(value) - 7(count)'.
                            Now, I need to find the MAX of above result. Also I need to display top "FIVE" MAX count.
Initial step I tried as below to get the "MAX" count but didn't get the expected result.
        <g:evaluate>
              var inc=new GlideAggregate('incident');
                          inc.addQuery(   My queries   )
                          inc.addAggregate('COUNT','abc');     <!-- abc is a column in incident table-->
                          inc.addAggregate('MAX','abc');
                        inc.query();
      </g:evaluate>
        <j:while test="${inc.next()}">
            ${inc.getAggregate('COUNT', 'abc')}
        ${inc.getAggregate('MAX', 'abc')}
        </j:while>
Can anyone help me to resolve this!!!!
Sowmya
Hi Sowmya,
Can you try something like:
<g:evaluate>
  var count = new GlideAggregate('incident');
  count.addAggregate('COUNT','abc');
  count.orderByAggregate('COUNT','abc');
  count.query();
  var maxloops = 0;
</g:evaluate>
<j:while test="${count.next() &amp;&amp; maxloops ${AMP}lt; 5}">
  ${count.getAggregate('COUNT', 'abc')}
  ${maxloops += 1}
</j:while>
</j:jelly>
Sergiu
9 REPLIES 9
Hi Sergiu,
                  Thanks a lot. My requirement is same as above.   Can you please post the code snippet using <g:evaluate> and <j> tags because when I'm checking two conditions in while loop using "${AMP} / &&" I'm failing.
It will be a great help for me if you post the code snippet.
I have modified your code based on my requirement and the code snippet is as below
<g:evaluate>
count.query();
</g:evaluate>
<j:while test="${count.next()}">
</j:while>
</j:jelly>
and result is
Sowmya
Hi Sowmya,
<g:evaluate>
  count.query();
  var maxloops = 0;
</g:evaluate>
  ${maxloops += 1}
</j:while>
</j:jelly>
Sergiu
Hi Sergiu,
                  Thanks a lot for your great help. I did small change in while loop, instead of ${AMP}lt; I used &lt; and it is working fine.
                  Please help me out in knowing the difference.
                            I have faced issue with ${AMP}lt; and &lt;. Sometimes ${AMP} will work and sometimes &lt;. May I know when we need to use what and what is the difference.
Sowmya.
I also thought ${AMP} is required here per:
Extensions to Jelly Syntax - ServiceNow Wiki
but it seems you required the HTML format:
How to Escape in Jelly - ServiceNow Wiki
Sergiu
Hi Sergiu,
        Thanks a lot.
Sowmya
