Help - custom SNMP walk to pull serial number for OpenGear Management Controller
andy m_1
Giga Contributor
I've been working on trying to pull the serial number for OpenGear management controllers for too awful long!  Any assistance would be greatly appreciated!
I'm already discovering the devices with the only issue of not returning the serial number.
The serial number is being found by other discovery tools in my organization using the following OID:   iso.org.dod.internet.private.enterprises.opengear.ogStatus2.ogSystem.ogSerialNumber ( 1.3.6.1.4.1.25049.17.1.2), but as you can see from below, it's empty.
I've added custom SNMP walks in the SNMP fields related to the SNMP - Identity Info Probe, but no matter what, i'm unable to get a value back in the ogSerialNumber node of the XML returned by the SNMP Identity Input.
I've tried mutiple variations of numeric/text versions of the OIDs in custom snmp fields (both walk/table).
but as you can see from the SNMP dump performed on this device, the serial number is there under the expected OID
9 REPLIES 9
anything back on this? we're running into the same issues
It gets classified as an IP Router and uses that discovery pattern.
HarishKumarS
any solution for this issue im unable to get serial number for network gear acm7004 device
HarishKumarS
for OID - 1.3.6.1.4.1.25049.1.90
HarishKumarS
I was able to fix the issue by adding these code of lines in SnmpIdentityInfoParser script file and adding below snmp walk
this.addSerial('standard', snmp.getOIDText('iso.org.dod.internet.private.enterprises.opengear.ogStatus2.ogSystem'));
