Help! - I'm struggling to auto populate department field
Kiet1
I need help with auto populating the department field on the sc_task form.
I've created a new departmeent field (u_department_task) but would like it to be pulling the data from the Requested For field (requested_for)
Client script
function onLoad() {
    var user = g_form.getReference('requested_for', callBack);
    function callBack(user) {
        g_form.setValue('u_department_task', user.department);
Alka_Chaudhary
Hello @Kiet1 ,
Please Replace your script with below script:-
Client Script:-
function onLoad() {
	var req= g_form.getValue('request_item');
    var ga = new GlideAjax('departmentDetail');
    ga.addParam('sysparm_name', 'getDetails');
    ga.addParam('sysparm_req', req); //newValue will requester for
    ga.getXML(callback);
    function callback(response) {
        g_form.setValue('u_department_task', answer); // enter correct variable name here
Script include:-
var departmentDetail = Class.create();
departmentDetail.prototype = Object.extendsObject(AbstractAjaxProcessor, {
	getDetails: function() {
        var req = this.getParameter('sysparm_req');
        gr.addQuery('sys_id', req);
        if (gr.next()) {
            return gr.request.requested_for.department.toString();
    type: 'departmentDetail'
Please Mark my answers Helpful & Accepted if I have answered your questions.
Alka
21 REPLIES 21
@Kiet1
Mistake1: You haven't selected the field name in your onChange Client script, select field name as "requested_for" and try again please, if it will not work you can go ahead with Alka's solution
@Prince Arora I don't have the option "requested_for"
Hello @Kiet1 ,
Please try this solution.
I've tried to create the catalog client script but the dropdown for Variable name is empty
@Kiet1 , change the table to sc_req_item i.e requested item table. Then you can see the field.
