Help! - I'm struggling to auto populate department field
Kiet1
I need help with auto populating the department field on the sc_task form.
I've created a new departmeent field (u_department_task) but would like it to be pulling the data from the Requested For field (requested_for)
Client script
function onLoad() {
    var user = g_form.getReference('requested_for', callBack);
    function callBack(user) {
        g_form.setValue('u_department_task', user.department);
Alka_Chaudhary
Hello @Kiet1 ,
Please Replace your script with below script:-
Client Script:-
function onLoad() {
	var req= g_form.getValue('request_item');
    var ga = new GlideAjax('departmentDetail');
    ga.addParam('sysparm_name', 'getDetails');
    ga.addParam('sysparm_req', req); //newValue will requester for
    ga.getXML(callback);
    function callback(response) {
        g_form.setValue('u_department_task', answer); // enter correct variable name here
Script include:-
var departmentDetail = Class.create();
departmentDetail.prototype = Object.extendsObject(AbstractAjaxProcessor, {
	getDetails: function() {
        var req = this.getParameter('sysparm_req');
        gr.addQuery('sys_id', req);
        if (gr.next()) {
            return gr.request.requested_for.department.toString();
    type: 'departmentDetail'
Please Mark my answers Helpful & Accepted if I have answered your questions.
Alka
21 REPLIES 21
@Alka_Chaudhary it dosen't give me the option to change the table
@Kiet1 change the table from sc_task to sc_req_item highlighted in red.
@Kiet1  , change the client script table to sc_req_item table i.e requested item table and in field name select the requested for and use this script. It will work.
g_form.setValue("u_department_task", g_form.getReference("requested_for").department);
Prince Arora
Tera Sage
@Kiet1
Could you please try same script in onChange client script instead of onLoad as while loading the form "Requested for" field must be empty which results the empty department
-> Create an onChange Script
-> Copy paste same code
If my answer solved your issue, please mark my answer as  Correct & 👍Helpful based on the Impact.
Sandeep Rajput
@Kiet1 Requested for is a dot walked field from Requested Item (sc_req_item) table hence you need to update your script as follows.
function onLoad() {
   var user = g_form.getReference('request_item.requested_for', callBack);
I have tested this on my PDI and it works perfectly.
Please mark my answer correct and helpful if it manages to address your issue.
