Help me with variable editor (Formatter)
Natan Felipe
I need to display the value of the "Material type" field but the "material type" field is being cleared after activating read only in the formatter variable editor.
I want to understand why this is happening and where can I go to fix it?
I'm new to ServiceNow, I'm still learning a lot of things, to solve this problem I've already looked at business rules to see if there is any script with missing code.
Before the screen loads completely
After the screen loads completely
I thank you all for your help!
Narsing1
Hope its a RITM view. Please check these areas in your catalog Item.
Did you enable the UI Policy to run only on Catalog Item view / RITM level as well.  If so, try to uncheck in RITM level
Also, check the UI Policy Action for this variable whether you have checked "Clear the variable value".
Please mark it as correct answer if it helps
Narsing
9 REPLIES 9
Thanks!
Natan Felipe
Unfortunately I still couldn't solve the problem I didn't finish looking at all the onLoad scripts.
But thanks anyway!
rahulpandey
Hello Natan,
The probable reason would be an onload catalog/client script. Best way to debug this is by using JavaScript Log and Field watcher. Refer below screenshot to activate it(note, this works only with gsft iframe and doesn't work in new tab)
I tried to mimic this, and I could see the responsible script which clears the value. Screenshot below
Thanks!
Natan Felipe
Hello community,
I managed to find the solution to the problem, in the end it was just clearing the check box, I thank everyone who tried to help me and that your answer helped me and taught me a lot.
Thanks!
arrow showing the option where I deselected
