01-19-2017 02:30 AM
Hi guys I`m struggling with a reference qualifier.
I have a record producer.
1. variable, lookup box - list trade_name from Main table. variable name is 'subcategory'.
2. variable, List collector, list other_name from Sub table. this table also contains same trade_name field, same as for Main table.
Goal is to only display other_names on Sub table List collector where the trade_name is that selected on lookup box named subcategory
I can reach that!
Reference Qualifier on List collector: javascript:'trade_name='+current.variables.subcategory;
Variable Attributes: ref_qual_elements=subcategory,no_filter
Perfect, when I change the subcategory correct other names listed on the List. BUT. I want to List on the collector only the Active other_names. Can`t setup the correct reference qualifier.
So I tried:
active=true^javascript:'trade_name='+current.variables.subcategory; -- this load all Active other names, but ignores what I select on subcategory.
javascript:'trade_name='+current.variables.subcategory^active=true; -- list all the items including inactive, ignores what I select on subcategory
Tried some another combinations also No succes. Do you have any suggestion please? Thank you!
01-19-2017 08:46 AM
Hi Laszlo,
Sorry, it looks like the script that I referred you to is out of date; my apologies. The script on the original article on ServiceNow Guru is updated and contains a bit more, which I have included below as well. One thing to note as well is that this will need to be an onChange client script rather than an onLoad.
//Apply a filter to the list collector variable
var collectorName = 'other_name';
var filterString = 'trade_name=' + current.variables.subcategory + '^active=true';
//Reset the filter query
window[collectorName + 'g_filter'].reset();
window[collectorName + 'g_filter'].setQuery(filterString);
window[collectorName + 'acRequest'](null);
01-23-2017 05:32 AM
Robert, many thanks!
It is working, with two comments:
instead of current. I need two use g_form.getValue (script error saying that current cannot be used in client scripts)
Also, I need to move this client script into a global app instead of my scoped app, but I can accept this right now. (within app scope it says other_nameg_filter cannot be null. So this is what I have now and it seems this is what I need though I do some testing still. Many thanks for your help!
var filterString = 'trade_name=' + g_form.getValue('subcategory') + '^active=true';
01-23-2017 06:59 AM
Hi Laszlo,
Of course you are correct about current not being available client side; my mistake. Glad you were able to get this working!
