Help with Script Include to get Roles Based on Group and User
patricial
Ok I need some help please!
I am jammed up with getting this to work.
I have a catItem that adds a user to Group
I need to first check what roles the group has
Check what roles the user has
If the group has itil and the user has itil = success
If the group has appover_user and user has approver_user = success
If group has itil and user does not have itil = fail
If group has approver_user and user does not have approver user = fail
If group does not have either itil or approver_user = success (regardless of what roles user has)
Here is my script Include (My client script follows) in my client script I need to return a message based on which role the user failed on
So if the user does not have ITIL (User does not have ITIL message)
If the user does not have approver_user (User does not have approver_user message)
/******* script include *********/
var getRolesAjax = Class.create();
getRolesAjax.prototype = Object.extendsObject(AbstractAjaxProcessor, {
getRole: function(){
gs.log('>>>DEBUG: returnGroup Role() started...');
var list = [];
var grp = this.getParameter('sysparm_group');
gs.log(grp,'shipra0');
var grGroup = new GlideRecord('sys_group_has_role');
grGroup.addQuery('group', grp);
grGroup.addQuery('role.name', 'itil');//itil
grGroup.query();
while(!grGroup.next()){
//var rol = grGroup.role.getDisplayValue(); //group itil
//return 'success';
//continue;
var gr2Group = new GlideRecord('sys_group_has_role');
gr2Group.addQuery('group', grp);
gr2Group.addQuery('role.name', 'approver_user');//approver user
gr2Group.query();
while(!gr2Group.next()){
//var rol2 = gr2Group.role.getDisplayValue(); //group approver_user
//gs.log('>>>TRICIA Query GROUP APPROVER:' +urol);
return 'success';
//continue;
var usr = this.getParameter('sysparm_requestedby');
var grUser = new GlideRecord('sys_user_has_role');
grUser.addQuery('user', usr);
grUser.addQuery('role.name', rol); //itil from group
grUser.query();
while (grUser.next()) {
var urol = grUser.role.getDisplayValue(); //itil role
var usr2 = this.getParameter('sysparm_requestedby');
var gr2User = new GlideRecord('sys_user_has_role');
gr2User.addQuery('user', usr);
gr2User.addQuery('role.name', rol2); //approver_user role
gr2User.query();
while (gr2User.next()) {
var urol2 = gr2User.role.getDisplayValue(); //approver user
gs.log('>>>TRICIA Query USER ITIL:'+rol + " " +urol);
if(rol == urol || rol == ''){
continue;
//return 'success';
if(rol2 == urol2 || rol2 == ''){
gs.log('>>>TRICIA Query for USER APPROVER:'+rol2 + " " +urol2);
return 'success';
type: 'getRolesAjax'
/*******Client Script*********/
g_form.setValue('no_license', 'false');
g_form.setValue('request_license', 'No');
var grp = g_form.getValue('group_name');
var usr = g_form.getValue('requested_by');
alert('Calling getRole... ' + grp);
var ga = new GlideAjax('getRolesAjax');
ga.addParam('sysparm_name','getRole');
ga.addParam('sysparm_group', grp);
ga.addParam('sysparm_requestedby', usr);
ga.getXML(AsyncCall);
function AsyncCall(response) {
if (answer == 'success') {
g_form.setValue('request_license', 'Yes');
alert(answer);
else{
g_form.addInfoMessage('ITIL Role is required for Group Access.');
g_form.setValue('no_license', 'true');
Please check if this helps..
Script Include:
var isITIL, isAPUSER, isANYGRPROLE;
grGroup.addQuery('group', this.getParameter('sysparm_group'));
grGroup.query();
while(grGroup.next()){
grUser.addQuery('user', this.getParameter('sysparm_requestedby'));
if((grGroup.getDisplayValue('role') == 'itil')){
grUser.addQuery('role', grGroup.getValue('role'));
grUser.query();
if(grUser.next()){
if((grUser.getDisplayValue('role') == 'itil')){
gs.log('isITIL = true');
isITIL = true;
else
isITIL = false;
if((grGroup.getDisplayValue('role') == 'approver_user')){
grUser.query();
if(grUser.next()){
if((grUser.getDisplayValue('role') == 'approver_user')){
gs.log('isAPUSER = true');
isAPUSER = true;
else
isAPUSER = false;
if(grGroup.getDisplayValue('role') != 'approver_user' && grGroup.getDisplayValue('role') != 'itil')
isANYGRPROLE = true;
if(isITIL == true || isAPUSER == true || isANYGRPROLE == true)
return 'Success';
else if(isITIL == false && isAPUSER == false)
return 'Approver User and ITIL Role is required for Group Access.';
else if(isITIL == false || isAPUSER == false)
if(isITIL == false)
return 'ITIL Role is required for Group Access.';
else if(isAPUSER == false)
return 'Approver User Role is required for Group Access.';
Client Script:
ga.addParam('sysparm_group', g_form.getValue('assignment_group'));
ga.addParam('sysparm_requestedby', g_form.getValue('requested_by'));
g_form.addInfoMessage(answer);
14 REPLIES 14
Ok I will try this now
Thank you so much Shishir
I will let you know how it works
Shishir
I added some logging it's still not working
So the group has just approver_user and the user has no role
it comes back success
gs.log("Tricia this is the last group role " + grpname_itil   + " " +grUser_itil + " " +grpname_au + " "+grUser_au + " " +grpname_any + " "+ grUser_any);
Tricia this is the last group role undefined undefined approver_user undefined undefined undefined
Please try with below script, i just tested and it works for me.
var isITIL = false, isAPUSER = false, isANYGRPROLE;
grGroup.query();
grUser.query();
if(grUser.next()){
isITIL = true;
else if((grGroup.getDisplayValue('role') == 'approver_user')){
grUser.query();
if(grUser.next()){
isITIL = true;
else if(grGroup.getDisplayValue('role') != 'approver_user' || grGroup.getDisplayValue('role') != 'itil'){
if(isITIL == true || isAPUSER == true || isANYGRPROLE == true){
return 'success';
Scenario I tested:
group and user has itil role: success
group and user has approver_user role: success
group has itil role but user didn't have itil role : fail
group and approver_user but user didn't have approver_user role : fail
group has just neither itil not approver_user: success
thank you so much Shishir,
I will test it now this morning
Shishir,
Thank you so much this is working. I added loggin and I see the correct roles.
How can I get the response to return specific message in the client script
So if the user doesn't have the itil role and the group does Return message
and then if the Group has approver_user and the user doesn't return message
g_form.addInfoMessage('Approver User Role is required for Group Access.');
If group has both and user doesn't have any
g_form.addInfoMessage('Approver User and ITIL Role is required for Group Access.');
Similar to this but I am not sure I understand how this is getting passed back?
var hasNotRole = response.responseXML.documentElement.getAttribute("answer");
    if (hasNotRole) {
    var singular = "User {0} will be assigned the {1} role after adding"
var plural = "User {0} will be assigned the {2} roles after adding"
  // Extracting the translated message and replacing the parameters
    var keys = [singular, plural];
    var msgs = getMessages(keys);
    var msg = msgs[singular];
  if(hasNotRole.indexOf(",") != -1)
  msg = msgs[plural];
  g_form.showFieldMsg('group_name', new GwtMessage().format(msg, hasNotRole, "itil"), 'info');
g_form.showFieldMsg('group_name', new GwtMessage().format(msg, hasNotRole, "approver_user"), 'info');
g_form.showFieldMsg('group_name', new GwtMessage().format(msg, hasNotRole, "approver_user, itil"), 'info');
