how can I display values(task numbers) in notification body
kotab
Hello
i want to populate the sctask data on email notification body
TASK number :
closed date :
work note:
and i have one variable is  list collector if user select something  some value i need to put that value on notification body:
please refer above snap short based user selection need to populate on email body.
please help me on this requirement
pratikjagtap
Giga Guru
Hi @kotab
Add Content in Email Body: Use ServiceNow email scripting (${} placeholders) to pull task details dynamically.
<b>Task Number:</b> ${number} <br>
<b>Closed Date:</b> ${closed_at} <br>
<b>Work Notes:</b> ${activity.work_notes} <br><br>
// Fetch the list collector variable value
var lcVar = current.variables.list_collector_variable_name;
if (lcVar) {
<b>Selected Values:</b> ${current.variables.list_collector_variable_name} <br>
Exolanation:
${number} → Populates SCTASK number.
${closed_at} → Displays the closed date.
${activity.work_notes} → Shows the latest work notes.
current.variables.list_collector_variable_name → Retrieves the selected values from the list collector.
Mark helpful if this helps you
Pratik
Ankur Bawiskar
@kotab
Notification is on which table? what did you configure? share some more details and screenshots
You can simply use email body or email script and print the list collector variable value
Yes i created notification on sc_req_item table.
And also i tired via flow designer (sent email action) but i pull list collector sys_id's.
Notification created on Sc_req_item table. please help me with script ?
Hi Ankur
i created notification on (sc_req_item) table
Not working
