How do I make a Reference field Read Only but keep the 'Info' button?
Wayne Richmond
I am putting a Reference field on a form to another record. I don't want people to edit the field but I want them to be able to click the 'Info' so they can view / go to the record.
Read Only:
Non-Read Only:
I've tried making the field Read Only via a Client Script and a UI Policy, both get rid of the Info button. Any ideas?
Akash4
Hi Wayne,
Create a UI Policy on the reference field that you wanted to make as 'read-only'. Then, set the System Property "glide.ui.reference.readonly.clickthrough" to true.
This will allow you to access the Info button in read-only mode.
If you got the answer, please dont forget to mark this as 'Correct Answer', thank you.
Regards, Akash
If my response proves useful, please mark it "Accept as Solution" and "Helpful". This action benefits both the community and me.
21 REPLIES 21
I don't have a Geneva instance to try on, do you have any other instance on a different version to check if this is a version thing or something else?
-Anurag
We have Fuji P11 on our production instance. I've just repeated the same steps and get the same issue.
Midhun1
Giga Guru
Else you can add macro to that field.
Akash4
Hi Wayne,
Regards, Akash
Bulls Eye Mate!!!
-Anurag
