How do I make a Reference field Read Only but keep the 'Info' button?
Wayne Richmond
I am putting a Reference field on a form to another record. I don't want people to edit the field but I want them to be able to click the 'Info' so they can view / go to the record.
Read Only:
Non-Read Only:
I've tried making the field Read Only via a Client Script and a UI Policy, both get rid of the Info button. Any ideas?
Akash4
Hi Wayne,
Create a UI Policy on the reference field that you wanted to make as 'read-only'. Then, set the System Property "glide.ui.reference.readonly.clickthrough" to true.
This will allow you to access the Info button in read-only mode.
If you got the answer, please dont forget to mark this as 'Correct Answer', thank you.
21 REPLIES 21
Great, thanks for that! Good to know about these properties!
This is great. Is there a way we could do this with a catalog form UI script? I am looking for a way to do this for a catalog form, but not do this globally.  How would I set this property ( glide.ui.reference.readonly.clickthrough ) on that field; could i use g_form to call and set this property?
Daniel Borkowi1
Use readonly_clickthrough=true attribute in Dictionary for dedicated fields.
E.g. in advanced Dictionary view:
Bingo. This should be the accepted answer.
Maybe its because the Accepted answer is in 2016, limited attributes were available then 😁. And I am glad to see @Daniel Borkowi1 answer here!
