‎05-16-2016 06:26 AM
I am putting a Reference field on a form to another record. I don't want people to edit the field but I want them to be able to click the 'Info' so they can view / go to the record.
Read Only:
Non-Read Only:
I've tried making the field Read Only via a Client Script and a UI Policy, both get rid of the Info button. Any ideas?
‎05-16-2016 07:18 AM
Hi Wayne,
Create a UI Policy on the reference field that you wanted to make as 'read-only'. Then, set the System Property "glide.ui.reference.readonly.clickthrough" to true.
This will allow you to access the Info button in read-only mode.
If you got the answer, please dont forget to mark this as 'Correct Answer', thank you.
‎03-12-2025 06:33 AM
Hello Daniel ,
This solution works well with all the reference fields.Not sure how to make it work for LIST Reference fields, where I would like to access the 'i' button on a read only List reference field.Attached screen shot for reference
‎08-31-2018 12:21 AM
Anyone know why the default of this property is false? I think in most cases, people still want to refer to the information even though a case is closed.
‎09-05-2018 07:09 AM
Don't really know it, but in my opinion it is better to grant less rights as default than too much rights.
‎09-05-2018 06:55 PM
I agree. However, the info button is simply a preview and link to the corresponding item. Whether one can access the information still depends on access control. Is it correct?
‎10-10-2018 08:08 AM
Yes that's correct. If a ACL will not allow to see a information, than the Info-Button will not show this. FYI you see the sys_popup view of the records form with this Button.
