09-23-2020 11:00 AM
Newbie here with some issues.
When I add a Variable Set with Container Start, Container Split, Container End to a Catalog Item it displays correctly in Catalog UI but not in the Service Portal. The same Catalog Item has standard variables where I am using the Container options and that section display consistent in both the Portal and Catalog UI.
Is this normal? I'm in my PDI using Paris.
I will attach screenshots to try to explain.
Thank you,
Diana
User Interface (UI)
09-23-2020 11:10 AM
Also just verified. Only using a Container Split on a Variable Set works fine on Platform UI and Service Portal.
Kind regards,
Mark
2020 ServiceNow Community MVP
2020 ServiceNow Developer MVP
09-23-2020 11:29 AM
Did this solve your question? Or do we need to follow-up on this?
Please mark this answer as correct if it solves your question. This will help others who are looking for a similar solution. Also marking this answer as correct takes the post of the unsolved list.
Thanks.
Kind regards,
Mark
