How do you turn off SQL output when running a script in "Scripts - Background"?
seberly
Giga Expert
Getting something similar to the following for scripts run through the "Scripts - Background" module:
Time: 0:00:00.002 id: <instance name redacted>[glide.10] for: SELECT task0.`sys_id` FROM task task0 WHERE task0.`sys_class_name` = 'sc_req_item'....
It seems the equivalent SQL is being output for every GlideRecord DB transaction.   Thoughts?
Scott
Mwatkins
Do you have the glide.db.trace property set to true in your instance? (check the sys_properties table)
If it doesn't exist, try adding it and setting it to type boolean or string with value "false"
11 REPLIES 11
Matt, That did it!   Thanks so much! Scott
Mwatkins
You are welcome, Scott
