How to ADD Incident in to the Problem related list using ATF
saha23456
Hi Team,
Can anyone help With ATF Steps
How to ADD Incident in to the Problem related list using ATF.
i will able to click Add button.
I don't know how to filter and select
Steps:
14 REPLIES 14
MahathiVeeR
Hi @saha23456 ,
I don't think this is directly possible with Click UI Action > Record.
Try writing a run server side script to get the sys id of the record.
If my answer helped in any way, please mark it as ✅Correct & 👍Helpful.
Mahathi
can you help me the steps/code
I don't have it handy but i suggest for sample run server side validation script, check the OOB one for INCIDENT MGMT:Parent and Child Incident state sync up, this has similar test step to check child incidents. This might help you formulate a Run server side script.
Mahathi
Ankur Bawiskar
@saha23456
I was able to add all the records. Please use Click Custom Component UI Step and select the correct button
I don't think you can select specific incidents and then add only those
chipillasra
Mega Guru
  • Open the ATF Test Case
    • Navigate to Automated Test Framework → Test Cases.
    • Create a new test or open an existing one.
  • Create a New Step for Opening the Problem Record
    • Step Type: Open a New Form or Open an Existing Record.
    • Table: problem (Select an existing problem record or create a new one).
    • Action: Open Record.
  • Click the "Add" Button in the Related List (Incidents)
    • Add a step: Client Test Step → Click a UI Action.
    • Choose Related List: Incidents.
    • Select UI Action: "Add" (Button to add incidents).
  • Filter and Select an Incident in the Lookup Window
    • Add a step: Set Field Values
    • Field: Use the search filter to locate a specific Incident.
      • Select the Incident and click "OK".
    • Submit or Save the Form
      • Add a step: Click a UI Action → Click "Save" or "Update".
    • Validate that the Incident is Linked
      • Add a step: Field Validation.
      • Field: "Incidents" (Related List).
      • Condition: Contains INCXXXXXX
