How to add users in a list collector as approvers in a flow
03-11-2025 09:07 AM
I have a list field in a table which stores the list of Users (references user table). I'm looking for a way to add the user in this list field as approvals for an RITM in the flow designer. I've looked at some community pages where the suggested solution was to look up records and ask for approval in a loop and some articles are archieved. This did not work for me as the ask for approval action is accepting only reference fields and look up record is returning record type. Any help here is greatly appreciated.
01-07-2026 04:41 AM
Hope you are doing good.
💡 If my response helped, please mark it as correct ✅ and close the thread 🔒— this helps future readers find the
03-11-2025 01:26 PM
Hi @Tamilvanan T,
I hope you are doing well. You can do this by providing a script on your "Ask for Approval" Flow Action. I have just done the same on a Catalog Item. Here is the implementation and please adjust as per your requirements.
First I get all the variables from the requested item (That include my list collector for the users I want to request the approval from)
Scripted Ask for Approval Flow Action. You may adjust the first line of code so that it is gathering the sys_ids of the users (comma separated or array)
Script used:
var approvers = fd_data._1__get_catalog_variables.approvers;
return "ApprovesRejectsAnyU["+approvers+"]"
Results:
07-01-2026 12:59 AM
Hello Medi.
Thank you for your solution here.
I was having the same issue and your solution was very helpful!
