How to auto populate due date filed on problem and problem task table
pvv1045330
I need to auto populated due date value on problem and problem task table based on priority values.
ex: if priority is 1 due date is +7days need to populated on due date field
  2. if priority is 2 due date is +10 days need to populated on due date field
3. if priority is 3 user will be enter the date manual, if not fill make a field is mandatory.
How can we write script for above scenario
Sirri
Use GlideDateTime based on your conditions.
pvv1045330
if priority is 3 or 4 user fill the due date manual, if he not make mandatory field on problem and problem task.
How can we make due date field mandatory if problem 3or 4
I am using below script
var datevalue = current.priority;
    var days1;
    if (datevalue == '1') {
        days1 = 14;
    } else if (datevalue == '2') {
        days1 = 2;
else if (datevalue == '3' || datevalue == '4' || datevalue == '5') {
        current.setValue('due_date','');
if(days1){
    var ed = new GlideDateTime();
    ed.addDays(days1);
    current.due_date = ed;
