How To Check Differnce Betwen Two Dates Using Client Script
Hello All,
I am new in ServiceNow Development can anyone please guide me on how to check the difference between the two dates?
my requirement is I want to find the difference between the date of creation of the incident and the date of updation of the incident.
Thank You.
anubhavritolia
Hi @Community Alums
If you are looking for Date Difference when Incident is Updated, it is more recommended to use After Business Rule on Update with your required Condition. Use below code there:
var duration = gs.dateDiff(current.sys_created_on.getDisplayValue(), current.sys_updated_on.getDisplayValue(), false);
current.<duration_field> = duration;
Still if your situation as to use Client script, you can use below code:
Client Script:
var strt = g_form.getValue('sys_created_on');
  var end = g_form.getValue('sys_updated_on');
  var ajax = new GlideAjax('AjaxDurCalc');
  ajax.addParam('sysparm_name','durCalc');
  ajax.addParam('sysparm_strt',strt);
  ajax.addParam('sysparm_end',end);
ajax.getXML(DateDiff);
function DateDiff(response) {
  g_form.setValue('<duration_field>', answer);
Script Include:
Client Callable: TRUE/Checked
var AjaxDurCalc = Class.create();
AjaxDurCalc.prototype = Object.extendsObject(AbstractAjaxProcessor, {
durCalc: function() {
  return gs.dateDiff(this.getParameter('sysparm_strt'),this.getParameter('sysparm_end'), false);
NOTE: The gs.dateDiff() method is not available in scoped applications.
Please mark this as correct answer and helpful if it resolved, or mark this helpful if this help you to reach towards solution.
Anubhav Ritolia
ServiceNow Rising Star 2023
Hello, @anubhavritolia I am trying to achieve the same functionality Using g_scratchpad  but its giving object[object]in output .can you please guide me on this?
Thank You.
*-------------------------------------------DISPLAY BR-------------------------------------------------------*
// var gd1=new GlideDateTime();
// gd1.setDisplayValue(current.sys_created_on);
// var gd2=new GlideDateTime();
// gd2.setDisplayValue(current.sys_updated_on);
// var duration=GlideDateTime.subtract(gd1,gd2);
g_scratchpad.d=duration;
Hi @Community Alums
Not sure if Display BR would work here in this scenario. Better go with the solution I provided.
Anubhav Ritolia
AndersBGS
Hi @Community Alums ,
besides what @anubhavritolia @already have stated, if it is a date diff for reporting purpose on same record, the easiest way would be to utilize function field in reporting.
if my answer has helped with your question, please mark as accepted solution and give a thumb up.
Best regards
Anders
Best regards
Anders
Rising star 2024
MVP 2025
