How to create advance reference qualifier with if and else conditions
rahul16
Giga Guru
I am using a variable set and I am filtering conditions like
Application<category<sub-category
if there is no application then category<sub-category
javascript&colon; 'u_type=category^u_inactive=false^u_catalog_item='+(current.cat_item.sys_id||current.request_item.cat_item.sys_id)+'^u_application='+current.variables.application;
This will work only if user select application
How can I use it if the application is empty set the application as empty?
if(current.variables.application){
return current.variables.application;
}else{
return '';
I created like this
javascript&colon;if (current.variables.application != "") 'u_type=category^u_inactive=false^u_catalog_item='+(current.cat_item.sys_id||current.request_item.cat_item.sys_id)+'^u_application='+current.variables.application;else 'u_type=category^u_inactive=false^u_catalog_item='+(current.cat_item.sys_id||current.request_item.cat_item.sys_id);
but else part not working
Ankur Bawiskar
@rahul16
use this
javascript&colon; var query; if (current.variables.application != "") query = 'u_type=category^u_inactive=false^u_catalog_item='+(current.cat_item.sys_id||current.request_item.cat_item.sys_id)+'^u_application='+current.variables.application; else query = 'u_type=category^u_inactive=false^u_catalog_item='+(current.cat_item.sys_id||current.request_item.cat_item.sys_id); query;
19 REPLIES 19
Yes thank you what is the difference between "!current.variables.application" and this current.variables.application != "" ?
Why for me !current.variables.application this worked
when you use this !current.variables.application it means the value is not empty or not null
From a syntax perspective, I was expecting the last part to be "return query" rather than just "query".   But I'm still a novice in javascript.
TejasriK
javascript&colon; current.variables.application != "" ? 'u_type=category^u_inactive=false^u_catalog_item='+(current.cat_item.sys_id||current.request_item.cat_item.sys_id)+'^u_application='+current.variables.application : 'u_type=category^u_inactive=false^u_catalog_item='+(current.cat_item.sys_id||current.request_item.cat_item.sys_id);
syntax for if else condition is - condition ? executes if true : executes if false
specify the condition and if it is true then the line before colon will executes if the condition is false the line after the colon will executes.
TejasriK
