How to create Import Sets - Data Sources using script in ServiceNow Scripts - Background
Options
06-10-2018 11:43 PM
I want to create Import Sets - Data Sources with below setting using script:
How to create above Data Sources then Load All Records using script?
Tim
Labels:
Scripting and Coding
Options
06-11-2018 07:54 AM
Hi Tim,
I am not sure why you want to create all these via scripts i.e. data source, transform map, field maps etc
They are not meant to be created via script. Do you not have access to the instance where you are running this?
If you have access then what is the limitation of not creating it via left navigation?
✨ Certified Technical Architect || ✨ 9x ServiceNow MVP || ✨ ServiceNow Community Leader
